It is currently Thu Aug 21, 2025 6:07 pm
PostPosted: Fri Dec 03, 2021 1:39 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
I'm curious if anyone knows how this pickguard would have deformed in this way? It's swollen and turned opaque. Heat? Previous attempts to buff it? Very vigorous strumming? If there's anything to be done I'd like to do it. But I don't want to make it worse, and am fine leaving it as is.
PostPosted: Fri Dec 03, 2021 2:48 pm
It's called outgassing. The plastic is getting old and is deteriorating. No - it probably can't be saved.
These users thanked the author Chris Pile for the post (total 2): Hesh (Sat Dec 04, 2021 4:07 am) • Conor_Searl (Fri Dec 03, 2021 5:23 pm)
PostPosted: Fri Dec 03, 2021 3:27 pm
I have flattened warped pickguards by heating in the oven to about 200° F between a couple of aluminum plates. But that won't do anything for an offgassing nitrocellulose pickguard.
These users thanked the author Barry Daniels for the post: Conor_Searl (Fri Dec 03, 2021 5:23 pm)
PostPosted: Fri Dec 03, 2021 4:40 pm
I suspect the light splotchy areas are from the PG separating from the top.
These users thanked the author Pat Foster for the post: Conor_Searl (Fri Dec 03, 2021 5:23 pm)
PostPosted: Sat Dec 04, 2021 4:10 am
I was outgassing in the shop a lot yesterday and nearly made Dave sick :)
What Chris said, it is what it is. Notably that Yam has had the pickguard distort and come loose but no top cracks! We very rarely see a cracked Yam and here we see homeless folks carrying them outside in the winter with no cases too.
PostPosted: Sat Dec 04, 2021 1:26 pm
Easy button is to take that old one off. Order this one and put it on. Those were not built for the long term
https://www.backwoodsguitar.com/fg-300- ... atrix.html
These users thanked the author DanKirkland for the post: Conor_Searl (Mon Dec 06, 2021 12:31 pm)
PostPosted: Mon Dec 06, 2021 12:31 pm
First name: Conor
Last Name: Searl
City: Duncan
This ones got a plywood top, I'm sure that probably has something to do with the lack of cracks?
These users thanked the author Conor_Searl for the post: Chris Pile (Mon Dec 06, 2021 1:38 pm)
PostPosted: Mon Dec 06, 2021 8:24 pm
First name: Josh
Had an early 80s yam dread in this morning- mid-range model, well over 35 years old. Lifting bridge (up 1/8" in the rear but hanging on) and two busted x braces forward of the bridge - cracked all the way through. Spruce bridge plate all chewed up around the pin holes. Way-too-thin saddle leaning at almost 45 degrees in its slot. But hardly any belly or deformation of the plywood soundboard in front of the bridge. Perfect neck-angle, great action, sounded fine for a plywood guitar :D
Told the fella to just enjoy it for however much longer it hangs together, then grab another one from the pawn shop. He said he's never spent a cent on it since new other than strings. He sure got his money's worth out of it.
These users thanked the author joshnothing for the post: dbbrantley (Thu Apr 21, 2022 12:53 am)
